Tìm kiếm hỗ trợ
Tránh các lừa đảo về hỗ trợ. Chúng tôi sẽ không bao giờ yêu cầu bạn gọi hoặc nhắn tin đến số điện thoại hoặc chia sẻ thông tin cá nhân. Vui lòng báo cáo hoạt động đáng ngờ bằng cách sử dụng tùy chọn "Báo cáo lạm dụng".
Tìm hiểu thêm
How do I turn off developer console
  • 3 trả lời
  • 1 gặp vấn đề này
  • 2 lượt xem
  • Trả lời mới nhất được viết bởi cor-el
When opening a new web page the developer console shows up on the bottom of the screen and the page is locked. I close the console and the page works just fine. It even happens on the Mozilla site. How do I turn the console off.
Tất cả các câu trả lời (3)
"Apart from the "Close" button, Shift+F2 or the "Developer Toolbar" menu item both toggle the toolbar off."
-https://developer.mozilla.org/en-US/d.../GCLI
I have tried to reproduce it and cannot. Do you have a minimized window with the developer toolbar open? This would make it show up in a new window. Try closing Firefox and opening it back up.
This does not help. The console opened up even as I was logging in to respond. Is their a way to disable this option entirely. below is a snap shot of what is up" " _.-~-.
          7  Q..\
       _7         (_
     _7  _/    _q.  /
   _7 . ___  /VVvv-'_                                            .
  7/ / /~- \_\\      '-._     .-'                      /       //
 ./ ( /-~-/||'=.__  '::. '-~ {             ___   /  //     ./{
V   V-~-~| ||   ___   ':::.   ~-~.___.- _/  // / {_   /  {  /
 VV/-~-~-|/ \ .'__'. '.    '::                     _ _ _        .
 / /~~~~||VVV/ /  \ )  \        _ __ ___   ___ ___(_) | | __ _   .::'
/ (~-~-~\\.-' /    \'   \::::. | '_ ` _ \ / _ \_  / | | |/ _` | :::'
/..\ /..\__/ ' '::: | | | | | | (_) / /| | | | (_| | ::' vVVv vVVv ': |_| |_| |_|\___/___|_|_|_|\__,_|
Hi there, nice to meet you!
Interested in having a direct impact on hundreds of millions of users? Join Mozilla, and become part of a global community that’s helping to build a brighter future for the Web.
Visit https://careers.mozilla.org to learn about our current job openings. Visit https://www.mozilla.org/contribute for more ways to get involved and help support Mozilla.
If you don't want to see this message next time, run this JS statement:
   Tabzilla.disableEasterEgg()
" tabzilla.js:614:21 This site makes use of a SHA-1 Certificate; it's recommended you use certificates with signature algorithms that use hash functions stronger than SHA-1.[Learn More] captainbob1 This site makes use of a SHA-1 Certificate; it's recommended you use certificates with signature algorithms that use hash functions stronger than SHA-1.[Learn More] 751907 This site makes use of a SHA-1 Certificate; it's recommended you use certificates with signature algorithms that use hash functions stronger than SHA-1.[Learn More]
That looks like the Browser Console (Firefox/Tools > Web Developer; Ctrl+Shift+J)
This issue can be caused by an extension that isn't working properly.
Start Firefox in Safe Mode to check if one of the extensions (Firefox/Tools > Add-ons > Extensions) or if hardware acceleration is causing the problem.
  • Switch to the DEFAULT theme: Firefox/Tools > Add-ons > Appearance
  • Do NOT click the Reset button on the Safe Mode start window
